Configures a log target to receive events that conform to a specific EMS filter and severity level requirements.
upm_profile_name | Specifies a UPM log target to configure. |
filter-name | Assigns an EMS filter to the specified log target. |
severity | Specifies the minimum severity level for events sent to the log target. |
only | Specifies that only events at the specified severity are sent to the log target. |
N/A.
Events that meet the criteria established in the EMS filter and the optional severity requirements are forwarded to the UPM log target profile. You can further restrict the forwarded events with the following command:
configure log target upm {upm_profile_name} match {any |regex}.The following example configures UPM log target testprofile1 to receive events that meet the criteria defined in EMS filter testfilter1:
configure log target upm testprofile1 filter testfilter1
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the Universal Port feature, see the Switch Engine v33.1.1 Licensing Guide document.
